RCU Forums - View Single Post - landing problem
Thread: landing problem
Old 02-01-2003 | 10:40 PM
beepee
Default landing problem
corsair01,
What is the thrust angle of your engine? If your plane is ballooning on drop of the throttle, you may have too much down thrust. If you have down thrust, try cutting it in half.
If you can dial in some up in your ailerons for landing you may get a little bennefit. Small reduction in lift, a little less tendancy to drop a wing near stall (don't know your airframe and whether it has barn door ailerons, or tip stall tendancy) ... just some thoughts. The down side is that it will increase your landing speed a touch.
Let us know how it goes.
Bedford
