RCU Forums - View Single Post - Substitute for Ether
Old 01-09-2007 | 10:31 AM
  #695
merugo
Default RE: Substitute for Ether
Slope soarer,
thanks for your contribute. If you add 153ml of commercial mix 30% eth 24% cast 46%kero you add 46ml eth ,37 cast, 70 kero to your other components, as I have reported as your results in my proposed form. If you want you may vary it, editing as needed since it is really yours. but please mantain the outline of the form , it is intended to be used also by others.
To others,
pls why not to resume your formulas in this proposed form? It will take a few minutes and your experiences will not be disperded!
Ugo
MIX NUMBER: 01............................................SUGG ESTED NAME: SLOPER's.................DATE: 01/04/07
ORIGINAL REPORTER: SLOPE- SOARER.............LAST EDITOR: MERUGO........................ LAST EDIT:01/09/2007
ADDITIONAL USERS:............................................ ..
FORMULA (in order of decreasing percentage of volume ):
1)-43 % kerosene
2)-16 % modified olive oil
3)-14.5% ether
4)-12.5 % synthetic 10w40 Millers diesel oil
5)-11.5 %castor oil
6)-2.5 % EHN from ignition improver by Millers
The way the mix it was obtained: by mixing components with 15.3% of commercial fuel
ENGINES
1)PAW.2.49..CARBURETOR: RC .. RUN TIME: ...........STARTING: electric/primer USER:slope-soarer
Comments:used in 5-25°C range. worked well. 20' running times. throttle very good
2)PAW.1.49.CARBURETOR: fixed...RUN TIME: ...........STARTING:........................ USER:slope soarer
Additional users:
Nickname :........................ Observation:
Non user comments:
Nickname : merugo ...Comment: relatively high ether content. total oil seems too much
Nickname :................. Comment:
PURPOSE:
SHARE FORMULAS, EXPERIENCES AND SUGGESTIONS.
RULES:
EVERYONE CAN ADD HIS EXPERIENCE/ENGINE AND/OR BRIEF COMMENT FOR A GIVEN FORMULA by reediting and setting edition date
USE:
COPY; EDIT AND PUBLISH. NO CONTRIBUTION CAN BE MODIFIED IF NOT BY ITS AUTHOR
END
