RCU Forums - View Single Post - Flaps
Thread: Flaps
Old 01-09-2007 | 01:03 PM
mulligan's Avatar
mulligan
Default RE: Flaps
A little more feedback on flapersons and the washout aspect...
With typical wings, they can be designed such that the inboard portion of the wing will stall before the outboard portion- this is done either by using different airfoil sections at the root and tip or by twisting the wing such that the root always has a slightly higher angle of attack. This allows the ailerons to still be effective when the wing begins to stall (as the outboard of the wing is still "flying" while the inboard portion is stalled).
When you add flaps to the inboard portion of a wing, this simply adds to the above condition. Of course, the flaps greatly reduce stall speed and enables slower landings/steeper descents; and they do not take away from the desired early inboard stall characteristic.
Adding a flap mix to your ailerons upsets this desired early stall characteristic. By using flapersons, you increase the angle of attack of the outboard portion of the wing relative to the inboard portion (unless the ailerons run the full length of the wing). So, it is possible to cause the reverse of what is desired... the outboard portion of the wing will stall early. If this "tip-stall" occurs, the ailerons lose their effectiveness, and the plane may be uncontrollable once the stall begins.
Having said all this, it may or may not affect your plane significantly depending on how much flap is used, the geometry of the wing to begin with, etc. I am not familiar with your plane, but as it's a pattern ship, I would guess everything is symmetrical and no washout is built into the wing... which means your are starting with everything neutral... so you would certainly be adversely affected by adding flaperons. It is not a great idea if you can avoid it. Use flaperons only if you can't land without flaps, you cannot add traditional inboard flaps, and/or if your ailerons are the full length of the wing.
