RCU Forums - View Single Post - Substitute for Ether
Old 01-09-2007 | 03:17 PM
  #698
slope-soarer
Default RE: Substitute for Ether
Merugo,
Your listing of my fuel mix needs a slight alteration.....
castor oil is 8% (not 11.5%)
ether is 10% (not 14.5%)
If you like you can put in the "suggested name" slopers 10% ether mix.
Go ahead and use it.... Trevans should be an easier mix to write out
Treven,
Great to see you still having so much cheap fun. I would like to join in but it has hardly stopped raining since October, even if it's not actually raining everywhere is soaking wet []
Pity about the crash... still a good chance to strip down and examine the engine's innards.
Any decent gunge you scrape out of there could probably go straight back on the road surface
Reg
