In an automotive engine exhaust gas temperature also varies all over the map depend
In full scale aircraft the EGT is taken right at the exhaust valve. Not all over the place there. Infrared guns do not actually measure temperature. They measure infrared heat; the temperature they give is an educated guess. If you have a powder coated black engine and white engine running at the same temperature the gun will give a higher temp for the black engine because black radiates infrared light better. Likely the black engine would actually be cooler because black radiates heat better.
