RE: AirWild 29% Edge 540T has arrived!
Hi Barry,
It's coming pretty slow as I have two other planes on the table right now. The problem with that is that they are not mine. I have done some assemble so that I could take it to my graphics guy to get all prettied up. The only problem I see right now on the build is that the sleeve in the fuse for the stab tube is a little loose. I think I will probably put a piece of packaging tape around the tube to snug it up a bit. The stabs themselves fit the tube great. One other small problem was that one of the stabs where not slotted for the ca hinges. Every thing is mostly done for you on this plane. No holes to cut for servos or switches. I like that alot. It will be a quick build once I get into it. I have every thing except the engine. I can't make up my mind what I want to put on it. I'll keep you up to date as I progress.
