RCU Forums - View Single Post - Proper linkage setup on blade CX?
Old 01-09-2007 | 09:46 PM
nickrummy's Avatar
nickrummy
Default RE: Proper linkage setup on blade CX?
Thanks solo. I was flying with the blades he gave me which were pretty beat up. I put new blades on and that made a huge difference. I had to adjust the POT on the 4-1 to get the blades in sync. What is a good way to make sure they are even? if I set it on the desk and throttle up one click at a time should the blades start moving at the same time? is that the best way to get the first initial starting point? Then fly it and see if the tail rotates?
After that I will re-adjust the servo linkages the same way I did it the first time. Set the trims at neutral and adjust the linkage ends until it hovers nicely.
I also found that hovering 6" off the ground is horrible. You have to get at least 2-3' off the ground to get out of the blade wash.
