RCU Forums - View Single Post - Thrust measurement
Old 02-01-2003 | 07:59 PM
hdebruin
Default Thrust measurement
Funny, I had the same dilemma. Solved in as follows:
I put the plane on the floor, and attach a wire to the tail. I made a see-saw contraption with two balsa sticks at 90 degrees on a pivot point in such a way that the more the aircraft pulls, the more a balsa stick pushes down on an electronic scale. Voila, thrust in ounces, pounds, kilograms, whatever you like....
Dutch engineering, I tell ya.
Hans
