looks good neuro. I just got the tail and fuse built for the Slow Stick and glued the wing. Wing spars and electronics are next. I'm waiting on several shippers for that stuff. It's going to be set up with a 10x6 prop, 350 brushed motor, and 1500 mah 2s(cell?) lipo. I should be able to float it and then punch out if necessary.
Tim
Sad Face, when I fly in windy conditions I use a 30" x 1/4" silk ribbon as a tail, it keeps the nose down and allows flight without adding weight. In bipe mode you could probably use less ribbon. Unfortunately silk is the only material that seems to work well. Just a thought, Tim
