RE: TESTED DIESEL FUELS
Treven, this should be the right filling, edit if you want. Ugo
MIX NUMBER: .01...................................... SUGGESTED NAME: .Baker Black Brew mix.DATE: 10/01/2007................
ORIGINAL REPORTER: chevy43....................LAST EDITOR:.merugo...............LAST EDIT:..10/01/2007..............
OTHER USERS:
FORMULA (in order of decreasing percentage of volume ):
1)-64......%.Pump diesel..........................................
2)-15......%Chevron Dello 400 diesel crank case oil (Used).
3)-6.......%castor................................... ........
4)-6.5......%.ether.................................. ........
5)-6.5......%kerosene
6)-2.......%.Amsoil cetane booster.........................................
The way the mix it was obtained: by adding 1/5 of Davis plane mix, assumed for simplicity 1/3 ker 1/3 cast 1/3 eth .................................................. .................................................. .........
1)ENGINE:OS 40LA........CARBURETOR: RC.. .. RUN TIME: 7gallons......STARTING: hand w. chocking.. USER:chevy43...........
Comments:...3 min X oz fuel. good idling............................................ ...........
2)ENGINE:0.061 PAW......CARBURETOR:.........RUN TIME: ...........STARTING:........................ .. USER:...................
Comments:..difficult starting.......................................... ...............
Additional user observations:
Nickname :........................ Observation:
Non user comments:
Nickname : merugoComment:.This should be the right filling of the form.............................................. ........................
Nickname :................. Comment:.......................................... .................................................. .....
PURPOSE:
SHARE FORMULAS, EXPERIENCES AND SUGGESTIONS.
RULES:
EVERYONE CAN ADD HIS EXPERIENCE AND/OR BRIEF COMMENT FOR A GIVEN FORMULA by reediting and setting edition date
USE:
COPY; EDIT AND PUBLISH. NO CONTRIBUTION CAN BE MODIFIED IF NOT BY ITS AUTHOR
END
