RE: Major dave patrick Ultimate problem!!!
Would it be possible to use the heat method, and jam a shim in under one side and on top of the other side to help square the stab? Will the epoxy get soft enough for that? Perhaps heat it, lift it using some sort of wedge and push in a piece of wedge shaped balsa or hardwood to try to shim it?
Just a suggestion. At this point you have nothing to lose!
DS.
