RCU Forums - View Single Post - Major dave patrick Ultimate problem!!!
Old 01-10-2007 | 12:25 PM
bruce88123
Default RE: Major dave patrick Ultimate problem!!!
ORIGINAL: CGRetired
Would it be possible to use the heat method, and jam a shim in under one side and on top of the other side to help square the stab? Will the epoxy get soft enough for that? Perhaps heat it, lift it using some sort of wedge and push in a piece of wedge shaped balsa or hardwood to try to shim it?
Just a suggestion. At this point you have nothing to lose!
DS.
Wouldn't he need to remove material on the other side first so that it would have a place to go. It is mounted into a slot isn't it? I envision the fuse side splitting if the material was not removed first.[:@]
