RE: Phaeton 90 Build
Iron cross, you have it backward, upper wing negative with respect to lower wing. This has held true on at least the last 7 bipes I have built. Charlie P, no, all my bipes (for best flying and no elevator trim change being required with throttle change) like lots of down thrust. If you do not, you will have to fight the elevator trim every time you change throttle settings.
