RCU Forums - View Single Post - Running 2 Batteries on 1 RX
Old 01-10-2007 | 05:02 PM
rlipsett
Default RE: Running 2 Batteries on 1 RX
plug the battery into a separate switch then plug the switch into any open servo connection. all power connectors are on the same buss so it doesn't matter if power is plugged into a battery or a servo connection it is the same connection point. I can not answer about the battery being enough because you have not stated to mah of the battery.
