RCU Forums - View Single Post - Signal problems.
Old 01-10-2007 | 06:19 PM
Dugster's Avatar
Dugster
Default RE: Signal problems.
Try it with the antenna only half way extended. This will help with the close proximity swamping of the receiver problem. Yes, this will shorten the range. But then the full range on these radios is something like several miles, so you will only be able to control your tank out to half a mile or so.
