RCU Forums - View Single Post - How cold is too cold to fly?
Old 01-10-2007 | 07:28 PM
Rcpilot's Avatar
Rcpilot
My Feedback: (78)
Default RE: How cold is too cold to fly?
ORIGINAL: CGRetired
No sweat. Just don't run out of patients if it won't start right away. 50 degrees is not like 70 degrees. It wil take a few moments to warm up enough to start. Just use a good glow driver and turn it with an electric starter. As I said, it may take a few revolutions (maybe 20 or 30 seconds) of constant turning, but give it a go. Do it twice or three times till it starts. After it does start, it will be much easier to start once it runs out of fuel or you shut it down momentarily. Just make darned sure you run it very rich on the first couple of tank fulls no matter what the temperature is. Rich enough for the engine to pump out blue smoke and spit oil, and go from a smooth two stroke sound to a rough four cycle sound. Run it at a constant full throttle with a very rich mixture, for about 30 seconds, then back off for about 10 seconds, then back to full throttle. In the second tank, after about a half tank has burned away, lean out the mixture at full throttle till it stops four-stroke sound, run it for about 10 seconds, then back to rich for about 30 seconds, then repeat. This will give you the best results and will break it in.
This method of breaking in a new engine is completely contrary to all conventional methods of break in. Running a new ABC, ABN engine 4-stroking rich during break in is going to do more damage than good.
Read this:
http://www.rcuniverse.com/forum/m_1850473/tm.htm
^^^^^^^^^^^^^^^^^^^^THATS how you break in a new ABC engine.
NOT 4-stroking rich for 1.5 tanks. Thats the absolute worse thing you can DO. If your gonna start it up and 4-stroke it all stupid rich--you may as well pull it out of the box and hit it with a sledeghammer. Save yourself the trip to the field--same end result--ruined engine.
