RCU Forums - View Single Post - NEXSTAR ARF .....PROBLEMS...PROBLEMS
Old 01-10-2007 | 09:52 PM
  #110
AugerOne
Default RE: NEXSTAR ARF .....PROBLEMS...PROBLEMS
bought my nexstar used at a lhs...came with these little blocks attached to the servo horns with set screws that the pushrods run thru...they make the nose gear adjustment really easy...don't know if these are stock but i really like them.
as for the right thrust, i had the same problem at WOT. I just installed washers behind one side of the mount to correct. 1/2 throttle take off is plenty and no tendency to yaw. I'm guessing that they attemted to counter the natural left turn tendency and over compensated.
I read earlier posts about the wing bolt being stripped out. I tighten mine with a small screwdriver between two fingers until it gets hard to turn. Never a problem and no slop.
