RCU Forums - View Single Post - MICRO BALLOONS
Old 01-10-2007 | 11:49 PM
shd3920
Default RE: MICRO BALLOONS
ORIGINAL: bruce88123
http://www2.towerhobbies.com/cgi-bin...?&I=LXBH71&P=7
finishing resin.
BTW - easier to sand with more baloons, harder with less.
RESPONSE: Yes, I read that on the container as well. Is that finishing resin you mentioned what the polyester resin is?
Where are you using this mix at?
RESPONSE: Right now I only used it around the Trailing Edge Center Pieces to fill gaps. But if I got good responses from other members I was going to consider using it in place of filler in all the dings, gaps, and dents throughout the plane. That is why I am asking for opinions before I go ahead and do that. But I wanted to test it somewhere so I choose the Center pieces as stated. I take it you don't think that is a good idea
