RCU Forums - View Single Post - Foam in transmitter case
Old 01-11-2007 | 02:24 AM
bigtim
My Feedback: (13)
Default RE: Foam in transmitter case
I replaced the foam with the larger cube size the 1X1 same type just larger squares it holds together better than the smaller stuff.
I just used the extra foam I had for battery padding a 3X5 piece works well, pop the center cubes out and it holds a square battery great, also it is great for fuel tank padding, tear it to fit the size you need .
