RE: Good First Planes
West the prop designation means 4.5 is the diameter and the 4 is the pitch
Not sure how to tell you to get used to orientation, what I did was sort of turn the same direction of the plane untill I got used to it
A folding prop is used more for gliders, it is so when you cut the throttle it will fold and create less drag and when you land it will be folded and not drag on the ground
