2 servos on one surface 9zap
Ok , I'm using jr8411's. I ran the SRV test function and graphically the servo (aux2 or ch8) only moves about half way or 90 degrees.
On one other screen the only graphical display only shows movement in the "A" area. It is not proportional as you said. No where in the manual does it explain what is happening...poor explaniations. The Futaba FAQ was no help either.
I'll try the other channels and see if that makes a difference. Can you get, with mixing, subtrim etc., two servos to work together so as not to fight each other and still be able to trim the master channel with out using a Match box? Thanks again, Lou
