2 servos on one surface 9zap
I'll try the other channels and see if that makes a difference. Can you get, with mixing, subtrim etc., two servos to work together so as not to fight each other and still be able to trim the master channel with out using a Match box?
Absolutely, Lou... Keep on it you'll figure it out.
A simpler approach might be to use an unused p-mix such as p-mix #4 that already exists and change the slave servo to the channel that you choose. Which could be channel #5, unless you used it for the second elevator servo.
Michael
