RCU Forums - View Single Post - NEW CESSNA 182!!
Old 01-11-2007 | 02:56 PM
  #157
Quax4412
Default RE: NEW CESSNA 182!!
teamhighrpm: thanks! The rudder control is what me scared! Therefore I changed it into a pull to pull linkage. It`s o.k. now. I`m still wonderring whether I should also change the elevator control. But I don`t want to do so much work.[:'(] But better than crashing the plane... But you are happy with the original elevator linkage – right!?
citation560v: sorry I diddn`t see that you were referring to my claims above but you got the problem(s) of rudder & elevator right! The push rods in the fuse can flex easily (both rudder and elevator) and the metal wire that should be glued in the rudder has no support in the aircrafts tail. I tried to glue in two wooden stabilizers: one for the carbon push rod and one for the metal wire in the tail. But the result was not satisfying me at all. I´ve heard about an update version of the kit. Do the changes refer to the rudder control only or also to the elevator? What about your experiences?
I`ve written some information about that in tmw09`s building thread.
Quax[8D]
