RCU Forums - View Single Post - The Scorpion Arrives
Old 01-11-2007 | 06:16 PM
  #302
john agnew
Default RE: The Scorpion Arrives
Malcolm
Thanks for that. Mine is just about the same, CG is now set at 165mm back from the wing root. I was slightly worried that I had moved the CG behind the main wheels but with the model fully loaded the struts compress a little and this moves the wheel centreline back about 10 - 12mm .With the main tank full the CG will move forward slightly.
John
