RE: Building a Top Flite GE 1/8 scale F4U Corsair
CorsairJock,
I plan on using a pull/pull system hooked to the same servo as the rudder. I don't see why this shouln't work. Right is right and left is left. I will use a double horn on the rudder servo and have the tailwheel on the outside hole so it will turn better on the ground. Do you think this will work alright? How does everybody do it on the Giant scale Corsair?
Gibbs
