RCU Forums - View Single Post - Squewd wing...
Old 01-11-2007 | 08:07 PM
seeme323
Default Squewd wing...
OK I had a previous post about the trailing edge, but after holding it bowed in the opposite direction it is about straight. The problem is that still the aileron is not straight with the TE (about 1-2cm), and I've used a straight rule on the TE the LE the main spars and even the ribs once all built up with just the TE missing and lastly the aileron, all individually they are straight but when I put it all together something goes really funny and the things just will not go straight, I hope to be receiving new TE's and main spars from Great planes as I thought those where the problem before I straightened the TE. The ribs also when piled and using a angle to keep them straight are all about the same (off by max of 1mm) so if anyone has any ideas about this or has built the PT-60 trainer and can give me some pointers it be great cause now I'm all out of ideas.
Dave
