RCU Forums - View Single Post - SV27 Battery Thread
Old 01-12-2007 | 12:52 AM
  #527
Speederson
Default RE: SV27 Battery Thread
LOL this is better then the meds. Post #451 This thread.
There is a fifth to but Nobody knows.
ORIGINAL: Blackjack52
Speederson,
You had to add a fourth dimension didn't you. 3 just isn't good enough.
If you want a set of 4500s for testing, it should be good, but not for race trim. The added wopping 5 grams. But, as I was testing the 645, the 4500s handled the larger prop better this time. Setup on the loose water must have been just right not to fry them since they normally generated more heat just due to run times and constant WOT running. I use the 4500s for trim testing so I don't have to worry about having to swap packs so soon. Just a hint.
But next order for replacements to the 4500s will be 4200s. That way I can use them for race or trim trials. Best of both worlds. That is unless we start seeing some good results fromWazool on the A123s.
