RE: TESTED DIESEL FUELS
MIX NUMBER: 03............................................SUGG ESTED NAME: SLOPER's LOW ETHER MIX..DATE: 01/04/07
ORIGINAL REPORTER: SLOPE- SOARER.............LAST EDITOR: MERUGO......... LAST EDIT:01/12/2007
ADDITIONAL USERS:............................................ ..
FORMULA (in order of decreasing percentage of volume ):
1)-43 % kerosene
2)-16 % modified olive oil
3)-14.5% ether
4)-12.5 % semi synthetic 10w40 Millers diesel oil
5)-11.5 %castor oil
6)-2.5 % EHN from ignition improver by Millers
The way the mix it was obtained: by mixing components with 15.3% of commercial fuel
ENGINES
1)PAW.2.49..CARBURETOR: RC /fixed.. RUN TIME: ...........STARTING: electric/primer USER:slope-soarer
Comments:used in 5-25°C range. worked well. 20' running times. throttle very good
2)PAW.1.49.CARBURETOR:RC/ fixed...RUN TIME: ...........STARTING:........................ USER:slope soarer
Additional users:
Nickname :........................ Observation:
Non user comments:
Nickname : merugo ...Comment: relevant total oil content, should spare the engine
Nickname :................. Comment:
PURPOSE:
SHARE FORMULAS, EXPERIENCES AND SUGGESTIONS.
RULES:
EVERYONE CAN ADD HIS EXPERIENCE/ENGINE AND/OR BRIEF COMMENT FOR A GIVEN FORMULA by reediting and setting edition date
USE:
COPY; EDIT AND PUBLISH. NO CONTRIBUTION CAN BE MODIFIED IF NOT BY ITS AUTHOR
END
