RCU Forums - View Single Post - Perry pumping air!!!
Old 02-01-2003 | 07:14 PM
Boomstriker
Default Perry pumping air!!!
I installed a Perry (regulating) pump on my Skybolt/TT-120 last summer to move the tank on CG and for better fuel delivery.
It ran great last summer. The weatherman says in the 60's Sunday so I spent all morning trying to get this thing to run for more than a few seconds.
It pumps good up to half throttle but more than that it starts to pump air straight to the carb. The air is coming from the case/pressure side because there are no air leaks in the tank and no bubbles in the line up to the pump, only after it.
I thought vibes were causing this but it still does it un-mounted.
Adjusting the screw raises and lowers the pressure correctly while it's pumping solid fuel at 1/4 and lower, but when I go to 1/2 throttle the air bubbles start coming from the pump.
It pumps solid air at full throttle and dies as soon as the line runs dry.
The pump has only seen a few flights last summer, but mostly sits.
Anyone else experience this?
Do the diaphragms deteriorate this soon?
Are these things re-buildable?
Thanks for any help!!! Kirk
