RCU Forums - View Single Post - Walkera Dragonfly #36
Old 01-13-2007 | 10:12 AM
  #6034
Rattlecat
Default RE: Walkera Dragonfly #36
Jackedman,
Be careful, you seem to be new to this. This hobby is loaded with dominoe players that will keep you on an endless chase for the part that will work or work more than a few flights. A this and a that will make it work. None such luck. And watch out for those search engines. They can send you to a custom made trap. They could draw every penny you have and leave you stuck, almost working, but not quite. At least that is what they did to me.
The flyers on the forums will mostly try to help, but it is past their ability to control what the vendors send you. After some failure with Walkera, the search engines will send you to a Trex. Read up on them. Same garbage. Oh the Trex is great. By the way, I had to replace the one way bearing after one flight, the motor bearings go bad, the head loosens up, the blades won't track, the esc's go bad. It's all there. So what's with the game ? Making someone go broke and giggling is a bad game and will loop right back around on the player when everyone around him is the same. I intended to learn some things, but this is rediculous. I am trying to stop, but I am so close to getting it to work.
Every try takes a week to deliver. Pay the vendor, pay the shipper , it don't work. The search engine leads you to a solution. Same result, pay, wait, no luck or it only lasts a few flights.
I think I made a mistake getting into this.
SB
These vendors know what works and what don't. They play dumb.
