RE: KMP Edge 540
Thanks tom for the advice on the cowl placement. The wing tube is no big deal. I rather it to be tight rather loose. I would disagree with you on the cowl issue. I have always mount the engine with the pitch and trust line in the fire wall. If the line is not marked, I center it on the mount with the shaft in the center of the fire wall. I whould think that the cowl could and most likely be off. I will think of something.
