RE: Where to install a fuel dot???
Pardon my ignorance but if you start pumping fuel into the '3rd' tube and your needle valve is open to the standard 2-3-4 turns, won't it flood the engine? Or does the 'path of least resistance' play here and air pressure is exhausted to muffler line - thus no worries.
I too am setting up a fuel-dot contraption and wanted to make sure this wouldn't be the case. Also, how do you know when to stop filling with a 4-stroke....just watch fuel come out the muffler?
Thanks!
Wiqar
