Angus,
Great craftmanship!
Please continue to post more pictures of your build. I want to learn from a master.
ORIGINAL: Angus McDonald
I removed most of the underside and built up some of the spars as well as add another one. Then I glued in a mount for the retracts similar to a flex plate. I moved the servo well over for the ailerions. When I pulled off the balsa sheeting to remove the existing mounts and do the build up, I sure noticed the poor and lack of gluing done inside.....I'm not sure if I would put a turbine on one, it's going to give sooner or later. Anyway I re-glued everything and did full sheeting so I can glass it.
Angus
