New to this forum me and my models
Hi! My name is Richard I'm 24yrs old and live near the city of Gothenburg in Sweden. I've been building models for 2yrs.
These are my models
Robbe Dolly
A small work launch built from a Robbe kit.
Length: 560mm
A styrene/balsa barge for towing
About 600mm length.
see barge.jpg.
An experiemental electric ducted fan boat
This was an experiment build it doesn't go very fast or steer very good
Length about 600mm
Victory EP
Chinese RTR Speed boat
with two direct drive 380motors
on twin propps and one six cell battery.
This is a very fast boat for it's price only problem
is that the included radio doesn't allow proportional throttle
and there's no rudder.
Steering is done using only left or right propp.
You've probably seen similar boats at your local hobby shop
See victoryep.jog
Graupner Hydro Speed
Fast Electric Graupner Hydro Speed old kit.
Currently 6cells. Modifying for 12cells.
The balsa box on the canopy is to accodomdate for a box
for my esc.
Length about:600mm
Robbe Sea Jet
A fun boat. Handles choppy waves very well.
It just bounces it doesnät cut them.
Very stable in choppy waters.
Certainly a boat I recommend.
Six cells. Two counterrotating propps using a gear box
and one 600 engine.
A plywood barge-my latest project, still in construction, appearance changing
The boat is built like a plywood box. The sides are screwed together with using a Battery Drill and 30x3mm
wooden screws. I haven't used any extra frames. It's not meant to be beautiful, it's mean't to be sturdy and robust.
The boat has no exact replica but is meant to be a semi scale barge. The steering will be done through two independently
controlled motors and two independently controlled rudders. The huge compartment in the middle of the boat is the battery
compartment.The idea is that you can move the batteries to adjust the center of gravity.
Please feel free to contact me if you have any questions, photos of r/c barges, experiences building
r/c barges and other flat bottom r/c boats or just want to discuss r/c scale boat modelling
Material:
Regular non-waterproof 12mm plywood
Paint:
2Layers Solvent based blue wooden paint inside and outside
+3layers wooden boat varnish inside and outside
Technical facts
2xRobbe Power 600/24 Motors
2xRobbe Gearbox reduction 3.7:1
2xRobbe 3-blade 50mm propellers
2xElectronize FR-15 Speed Controllers
1xHitec 2Channel receiver
1xSanwa Dash 2Ch transmitter
2x7.2v 3000MAh NIMH batteries Mean Green Power Kyosho
2xRobbe rudders has replaced the two nozzles seen in the photos
2xHitec standard steering servos
Length 125cm
Width 30cm
Height ca 9cm
Depth in water: ca 2-3cm
Displacement approx: 7kgs
Weight ready to run: 10-12kgs
See images with name wrkboat..,jpg
