Is yellow cell 1? then blue is cells 1 and 2? and red is all 3 cells??
That would be my guess. individual cells should only be *****g out at 4v , they are wired in series to make your final voltage 11.1V I use a digital voltmeter on mine...and only check output voltage on the jst connector..and it reads at 8.28V for a 7.4 800 mah lipo. Go to
http://www.commonsenserc.com/page.ph...913ff45976e3f7
check that out and see if that helps you any.
__________________________________________________ ______________________
Of all the things I ever lost......................... I miss my mind the most!
