TT pro .61 HELP!
Twilli77, Start with the high speed needle and run it wide open and adjust it peak rpm, then richen it until you get about 300 rpm drop. Then let it idle for about 30 seconds and pinch the fuel line. If it revs up, it's too rich. Adjust the low needle about 30 degrees in.(clockwise) Re-pinch the fuel line again to check. If it dies when you pinch it, it's too lean, turn the low needle out (counter/clockwise) about 30 degrees. You should get a very slight rev up when you pinch the line, but not much. Re-set the high speed needle one last time. Check the idle for about 30 seconds again and see if the transition is ok. That should get you up and runnin..
Suptter
