RCU Forums - View Single Post - FS One by Hangar 9
Old 01-14-2007 | 07:41 PM
  #600
MSelig's Avatar
MSelig
Default RE: FS one by Horizon Hobbies
Jimeni -
In reply to another thread I posted a video (ground reaction
related). But the sounds on it are what the sim produces. Are you
hearing sound like this video:
http://www.inertiasoft.com/videos/Ul...dReactions.wmv
It is possible that we have the wrong type of engine sounds attached
to a specific airplane. Let me know if you think that's the case.
And, yes, some airplanes share the same sound files. This is very
common among simulators.
RealtyViking -
The Tx w/ the variable pitch prop was used to set the prop pitch
schedule for the full scale planes in the sim (e.g. the 100% Ultimate
TOC). The Ultimate EFL Tx belongs w/ the Ultimate EFL plane that's in
the sim. So when you pick that plane, that Tx should show up.
The two player, just plug in another other controller and click on
2-player. Then pick the new controller for the second person. You
don't need a second TacCon USB interface or TacCon controller - any
controller will do. You just need to have the original one plugged in
to the computer for things to work.
The "high lift" on the scaled down Ultimate might be related to a
light wing loading (lighter than you're expecting when scaling down).
Check the wing loading of the plane you're trying to match and then
use that in the Scaling Wizard (over-ride the auto scaling on weight).
Michael
