RE: Eletronic engine syncronizer **SUPPORT **
Guys,
A couple of guys have found a receiver with a minor issue when used with the TwinSync. The Hitec RCD-3500 receiver has a minor issue. If the transmitter is very close to the receiver with the antenna fully extended you can get some glitching. Fix is to put a resistor in the throttle signal lead (orange wire) between the Twinsync and the receiver with a value of 1.5 - 7.5K ohms. Email me if you have this receiver and I will send you a modified cable at no cost.
