RCU Forums - View Single Post - DA 85 Debuted today!!!
Old 01-15-2007 | 06:42 PM
  #45
nonstoprc's Avatar
nonstoprc
My Feedback: (90)
Default RE: DA 85 Debuted today!!!
$795 is a super price and the weight at 4.2lb is not bad at all.
ZDZ super 80 sells at $825, with the following specs:
Displacement 79.8cc
Bore 47mm
Stroke 46mm
RPM Range 1000-8500 RPM
Horsepower 9+hp
Weight 2000g/4.38 lbs bare w/plug
Fuel/Ratio Premium Gas mixed 40:1
Piston Rod 2 Needle Bearings
Crankshaft 2 Ball Bearings
Ignition ZDZ 4.8v-9v Electronic Microprocessor Controlled
Porting 4 Channel Hi-Flow
Prop Size 2 blade 26x10-12, 27x10 ZM 26x10 Carbon Fiber Prop Highly recommended = 6800-7000 rpm
3 blade 24x12, 25x10
