RE: 25cc 2-stroke conversion
After cutting the excess shroud from the engine casing, removing the cylinder, and splitting the case you can see that the conrod ends are supported by needle bearings while the crank is supported by caged ball bearings. The connecting rod appears to be plated with copper. Anyone have any idea what that indicates?
The case, cylinder, crank assembly, and carb together weigh in at almost 2 lbs.
