RE: Brillelli/Extreme Flight COMBO!!!
if you do it under you have to cut away some of the landing gear area i wasnt into that...i just cut that small top brace wich was basically replaced by the piece of balsa..also under the tank is a piece of bass wood between the balsa strips
