What grade fuel do you run?
Please take part in this poll. I have listed the most popular fuel grades. Also if you can give your expertise: What kind of mods can be done to these engines to give them more pep? (besides pipes) Can you raise the compression? adjust timing? larger carb? also do these engines use the same ported sleve as nitro or are there valves to play with? Thanx to all replies. Chris
