RE: CX PROBLEM NEED HELP DESPRATELY!
Also, besides binding, make sure your inner shaft reaining collar is properly tightened. If the set screws on the retaining collar aren't tightened on the shaft flats, the drive gear will spin around the shaft and unbalance the anti-torque effect causing the aircraft to spin.
