RE: MRC 969 Product Hazard Alert
That may draw the battery all the way down, but is not the proper way to do it. It is explained in manual.
Hook batt up to channel A and push discharge then start for a 3 amp discharge. You can also change the rate the same as you do on the charge if desired.
