RCU Forums - View Single Post - Converting from gas to glow
Old 01-16-2007 | 03:39 PM
jkhorvath
Default RE: Converting from gas to glow
OK, so, I've done the conversion from Gasoline to Glow fuel using all Gasoline components in the fuel system. Here's what I found out:
Gasoline components used in the fuel system for a glow fuel setup mostly works fine. I have no problems with the glow fuel attacking any fuel system component, however, the one issue I did find is the following. In a glow fuel system setup, most of the time you will run one line to the muffler for fuel system pressure. Note that this is not true for "pumped" glow fuel systems. However, if you need to run one line to the muffler, then you need to change that line to silicone. If you leave that line as Tygon, then the heat from the muffler will melt the fuel line (pressure line). Using a silicone line for muffler pressure will not be bothered by the muffler heat.
