RCU Forums - View Single Post - Ryobi 31cc - Variations between versions (i.e. 1 or 2 rings)?
Old 01-16-2007 | 05:27 PM
davewallace
My Feedback: (29)
Default RE: Ryobi 31cc - Variations between versions (i.e. 1 or 2 rings)?
J,
You can look through the plug hole, if you have enough light. The exhust is the best place to look with the plug removed. Homelite used a small hole above the exhust, half way up the cylinder. It went into the muffler. I tap the hole and plug it with a screw. Not so easy with the slots. There are so many venders and versions of the Ryobi, that it is hard to tell by model number etc.
Dave
