ORIGINAL: micro_builder
there are 3 channels for the AA, A B and C, they're all on the 27mhz frequency. if you both have the green one, you're probably on the same channel. its possible to switch channels, but it takes a good steady hand and some OK soldering skills.
Thanks nick, good advice. I am fairly good at microelectronic soldering. How does one change the channel for this AA biplane? I may go to channel C if I can. Does it take changing crystals, or jumper wires, or...??
Little-Acorn
