no problem. check out post #432 here for the channel changing mod:
http://www.rcuniverse.com/forum/m_33...18/key_/tm.htm all it takes is a little solder to jump the pads, or you can install a switch to change to any of the 3 channels at any time.
if you click on the AeroAce Sticky at the top of the forum and you'll find a good list of other mods that are worthwhile as well (the steering without throttle is a must for sure).
nick
