RE: SR Eindecker E1 Winter Build Along…
Nick - I'm not sure what camdyson is referring to as I didn't use the bellcrank for the rudder. We hooked the cables directly from the servo to the rudder.
The rudder slides up on the post each flight which is annoying. The cover of MAN showed the same problem in the issue where they reviewed the kit but the review doesn't mention it. In any case, the rudder isn't coming off but it sure looks stupid.
There's probably an easy way to fix it which might be putting a slot in the post and putting a screw through the rudder shaft to slide in the slot. Might be worth considering before you get there.
