RCU Forums - View Single Post - Air Hogs Aero Ace!
Old 01-17-2007 | 07:32 AM
  #4044
Djstinger
Default RE: Air Hogs Aero Ace!
FERN, I am now the proud owner of a acro-jet channel A ( RED ). I was at 2 Targets yesterday and they both had them, but only RED and I could not find what channel it was anywhere on the box I think the only channel out right now is A, I will be changing it to B tomarrow. What a perfect plane to put lights and landing gear on, I wonder if I can get it to ROG!!! I also found a ( only one ) SL battery for $7.48 I hope I can find some more...
NEW PLANE SPOTTED... BeeG was right there is a new plane at Target but it is made by Mattel not Tyco and is called SKYFORCE. This little thing is a great concept it comes with 2 gliders with removable guts. The receiver and battery are in a plastic case with 2 motors hanging from it. With some minor assembley of the gliders, you get to put the Rx/motors in which ever glider you want, thats right a portable Rx/motors/and battery that you can use for what ever you want. The best part is it uses a " LIPO " battery. I am not sure if it is the same guts as Air Hogs but it is worth checking out. I was going to get one but I had to have an AJ.
For more info on SKYFORCE check out Mirco-builders post in rcgroups.
